It is currently Fri Aug 22, 2025 4:37 am
 Post subject: Bending Ovangkol
PostPosted: Wed Nov 07, 2012 9:04 am
I'm experiencing a lot of springback on my first attempt at bending ovangkol. I have thicknessed it to 0.070-0.075 and am wondering if I should go thinner. Any info on how to deal with this wood would be much appreciated. Thanks.
Under Compensated Nut!
 Post subject: Re: Bending Ovangkol
PostPosted: Wed Nov 07, 2012 9:49 am
Some woods will do that ... wenge, bubinga, some mahagany .. just put it back in the bender adn run a couple heat/cool cycles, that should help. I dont worry much about springback in the bouts, its getting hte waist clse that concerns me. .. I dont like forcing that in with a caul, but the bouts usually flex in without much effort, and once they are blocked and kerfed, they are fine.
PostPosted: Thu Nov 08, 2012 1:44 pm
First name: Anders
Last Name: Eliasson
City: Beas
State: Huelva
Zip/Postal Code: 21630
Country: Spain
I´ve built a lot of flamenco guitars and most have been with Mediterranean Cypress, which is a stubborn backspringer.
I bend the sides in a fox style bender and I try to bend just before assembly. Just giving the sides time to dry. But even then, there´s a good deal of springback. So I´ve gotten used to always have the hotpipe ready when I assemble. Just a fast touch in the waist and evt. the bouts as well. The wais is by far the most important. The bouts can do with a bit of pushing and a few clamps. But not to much. I dont like to much stress in the build.
PostPosted: Thu Aug 22, 2013 2:53 pm
Hi,
I've just bent 2 sides of ovangkol, in was a real pain, as you described the springback is amazing!!!
I first let the sides soak in water for 1h, then made a pre bending (waist and upper bout), then I let them dry overnight.
On day 2, I soaked them again in hot water for 1h, and finished the bending with caution because on one side fibers inside the waist were starting to lift a little.
After the waist area was perfect and the upper and lower bout with a decent shape, I put them in the mold with the spreaders and let them sit overnight.
On day 3 in the morning, outside the mold, the sides are very nicely bent and almost no springback!
It is for an OM model, so bending the waist is really not a walk in the park.. but I did it! :D
Maybe I left the sides a little too thick, too..
I am also having big trouble thicknessing the back, tearout everywhere... I do everything with handtools..
PostPosted: Thu Aug 22, 2013 4:16 pm
First name: tim
Last Name: minkkinen
City: charlotte
State: nC
Zip/Postal Code: 28203
Country: united States
I've bent 2 sets of ovangkol. Very curly stuff. I spritzed with supersoft let set overnight in Kraft paper and bent it hot with no additional water. Pretty quick to bend. I also bend on a pipe so I can't say my methods apply. T
